$300.00 "VALVE JOB" MoPar Certificate EXPIRES 4/30
$300.00 \"VALVE JOB\" MoPar Certificate EXPIRES 4/30
Those of you with 2003 SRT Valve Jobs received a $300 certif for your inconvenience. I believe they EXPIRE the end of this month.
I may be wrong, but CHECK IT OUT and plan to pick up something from your Friendly Dodge Dealer...use it or lose it. Since most MoPar parts are VaporWare, it may be valid for routine maintenance items like a spare radiator hose, serpentine belt, Trunk Kit, '04 BOOT (BaackOrder) or ??
Dont waste the $300 ! call Chuck Tator, Bob Woodhouse, John Gastman, and redeem them for SOMETHING real soon!
GR8_ASP
Re: $300.00
I did not see an expiration date. How would we know???
GR8_ASP
Re: $300.00
Just pulled out the certificate and you are correct. Thanks Jon. It would have been wasted in 2 more weeks without your warning. :2tu:
Guess I should read the fine print next time :confused:
GR8_ASP
Re: $300.00
So, what can one order now for an SRT at a dealer? A bra, cover, floor mats and trunk kit is all I can think of. Possibly the boot cover if they come off of back-order. Course I have all of those things except the bra. Hmm. :confused: Ideas???
Paul Hawker
San Diego, Calif, USA
Re: $300.00
I am in the market for a SRT trunk kit. If someone wants to use their certificate up on that, I would buy it from them.
Please purchase it from a viper friendly dealership. One that supports this site.
Rich Carlson
N. Richland Hills, Tx
Re: $300.00
Jon is correct. Technically, the expiration date includes that the work be completed also. There a number of vehicles that have not had the work done for what ever the reason. If you where planning having the work done, I suggest that you contact your dealer to set a completion date.
Jay Herbert
Sunnyvale, CA
Re: $300.00
If you can use it for routine maintenance items.... oil, oil filters, air filters, tranny fluid (expensive stuff!) or parts that might be useful in the future, valve cover gaskets, maybe brake pads, or a clutch?
josesosa54
