1993 MODEL YEAR
Black exterior color introduced
Engine production moved to Mound Road Engine Plant
Engine color is a darker shade of red with a flat rough finish.
Motor oil filler cap changed to a threaded cap # 4573497 with "oil filler can" imprint and the valve cover is changed to accept this threaded cap.
Air conditioning added as a dealer installed option
Rocker exhaust covers have clear anti-chip tape on the front and sides in 3 places on both sides.
Plastic stanchion cover on both doors has 4 screws fastening the stanchion cover in place (no clips as on the '92)
1-Soft top latch holes on windshield frame have molded plastic cap with hole for latch.
-Removable rear window has snaps mounted in 3 flexible black leather tabs which snap to fixed snap buttons mounted on the ledge behind the rear seats.
At approx. build date 04/04/93 following changes occurred:
Rear antenna replaced by windshield antenna wire
Battery relocated to left rear fender (side away from fuel filler to make room for BUX rear exit exhaust)
Front caliper lettering changed from "VIPER" to "RT/10"
Reverse lockout added to transmission
Top Material Changed from Vinyl to Cloth
