MadMaxx
First, do the throttle cable sync.
Second, this is a common issue with part of the trans tunel being to short and flexes under initial load.
But to play it safe... check you driveshaft connections at the 3rd memeber, make sure the 3rd member has clean gear oil, and check your half-shafts.
Mine does it too, some of it goes away w/ the throttle sync. Both 93 and 95 cars I drove did it as well.
MM
MM
