LW VIPER
Sorry. Let's try again. 96 RT 10. Black with Silver stripes. Questions:
1. Can I go to any Dodge Dealer to determine who did the 998 999 recall work, assuming it was done?
2. The gearing was changed to reduce torque in the low end. I don't know the ratios. Assuming this was a standard changeout in 96 to reduce stress on drive train and increase mileage, what is the likely gear change, and how much faster will the car be traveling at 65 indicated than the speedo states?
3. The car had 8200 miles in 02 (I drove it then, and checked Carfax). In 04 it had 8800. I've driven a careful 300 miles plus since buying it, and other than some smoke on start up, that disappeared, I don't notice leaks on the garage floor. Dealer reportedly changed the oil once per year, and the battery recently. Should I let it go for a couple of thousand miles, or take it in and have all the fluids replaced now? Car seems to run fine.
4. How much for a dealer changeout to go back to stock gearing?
5. This car has the Gen II aluminum rear suspension, and the rear exit pipes.
I'd like to cool the sills (high flow catalytic converters?) and pick up the low end torque a bit more. Suggested mods, and an idea of prices if done by dealer?
6. Is it possible to get an extended warranty on a vehicle placed in service in 96, but with only 9200 miles on it now?
7. I'm in San Jose, California. Anyone know of very good mechanics for the Viper out this way?
Thanks very much. I'm working my way through the FAQs and historical comments, and considering joining the NorCal Viper group.
Larry
96 Viper RT/10
Black w/Silver Stripes
Larry
96 Viper RT/10
