97 gts key fobs
SurfSnake
New Jersey USA
It seems MGW discontinued their key fob covers, does anybody know of anybody else that might make some thing similiar, mine has cracked right were the key ring goes.
Dixter
Plano, Texas USA
Wow, I must have just bought the last one last week... I only
bought it because I got tired of the fob going off when I would
put it into my pocket. And it did fix that problem.
If I were you I'd try to get one off of Ebay... even if it
didn't work all your looking for is the case of the fob not
the guts....
Another trick I have seen done is to cut the bottom plastic
ring completely out and then drill a hole in one of the
corners of the cover.. then put the metal ring into the hole.
If you do it right you cant tell it was ever modified and it
was built that way from the begining.
Ron
Indianapolis
If you try Dixter idea, you might want to remove the circuit board before you drill.....
Andy
Darnestown, MD USA
I just dropped mine the other day and it busted in the same way. I got a new one from JonB for $45 or so, and JB welded (JonB welded?) the old one back together. It's nice to have a backup. The new one wasn't exactly the same and is almost small enough to fit in a normal pocket now.
They are easy to program to your car. No tools needed. There's an article in the latest viper magazine with the details.
SurfSnake
New Jersey USA
Thanks for all the ideas! I might just order a new one from the dealer and or try Dixter's trick. Getting tired of carring my key fob around in two peices
. If anybody sees a billet one flying around some where let me know!
FirecatF7
