98 Factory Hard Top ? & Where do you store yours?
ViperJoe
Virginia
This option was on the factory sticker, and I was wondering if a storage bag was included included (has the soft top and bikini cover in their respective bags)?
Does anyone make a storage bag?
How / where do you store yours?
Chuck 98 RT/10
tampa, fl USA
I have a storage bag that I think came with the ridiculously price rack. If I had it to do over I would build the rack out of pvc and go to a sail shop and have them make a bag.
slaughterj
I put mine upside down uncovered under my pool table - fits very well and doesn't interfere with play or walking around it, and doesn't get hurt there.
TRAMP 13
Montgomery ,Al
sat my on two towels in garage and had another towel between it and the wall and lean it against the wall.(Back wall of garage).
V
ViperJoe
Virginia
Chuck,
You mean like in sailboats?
99BLKRT/10
Austin, Texas
I went to Home Depot and bought some big "padded" storage hooks. I hang the top in the garage and lean it against the wall. I can email the pic to somebody if they don't mind posting it for the other guys to see.
BADVENOM
port washington, n.y. usa
Here you go! Looks simple enough
adam
V
ViperJoe
Virginia
99BLKRT/10,
Were those hooks padded from the manufacturer or did you use foam pipe insulation on them?
Does it just lean into the wall at the top?
BADVENOM
99BLKRT/10,
I believe those are just plain bicycle wall brackets with a piece of foam pipe insulation as you said
adam
Steve 00RT/10
Michigan
I use a similar method to Adam's(can't get that picture to come up?), but the back side down. I then cover it with a furniture blanket. In the winter, the soft top goes on the wall and the hard top goes on the car---unlatched--to keep pressure off the rubber seal. Make sure the 'L' brackets or bicycle hooks are long enough to get a good angle where it leans against the wall. if you can't have a good angle, a couple of bungee straps from a center point above will do the trick.
Steve
99BLKRT/10
Austin, Texas
ViperJoe,
The hooks came with insulation already installed. I believe they were about 4 bucks each. They are VERY sturdy and come with pretty long screws that can go into 2x4's. They are also long enough to allow the top to lean up against the wall.
AndyR
Cincinnati
I also use hooks from Home Depot. I think they are the same brand as the others shown above, but they can rotate flat when not in use. (see below)
V
ViperJoe
Virginia
One last question then I'm off to HD, Andy, do those "lock" in place when they are rotated out at 90 degrees?
Thanks suggestions and pics!!
AndyR
Cincinnati
Yes, they do have a stop to hold it in place when rotated out to 90 degrees. No worry about them swinging around on their own.
sham5430
