a/c fan switch question
vinny2
atlanta
on my 06 vert, the fan blows full on the highest switch setting ( all the way to the right), but when turning it to any of the other settings, it barely blows anything, and the same at each one. Any thoughts? Can i just get a new switch and install myself?
Thanks for the help.
V
vinny2
atlanta
that is certainly an option, but if it's easy to do, and cheap, i like to try things myself first. dealers are a pain the ****.
Racer Robbie
Guilford, CT-USA
The switch is not available separately. It is part of the AC Heater Control assembly. The part number is 4865 810AA, I believe. This control may not be your problem. I would opt for the dealer under warranty.
Robbie
Robbie
RAYSIR
Salem, OR
Usually when the switch is bad the speeds don't work. Sounds like the blower motor resistor block, which is in the HVAC box by the blower motor for cooling, under the hood. This is what changes the motor speed by changing the voltage to the blower motor. You can test the switch changing speeds here also on the different wires.:headbang:
GenV
