I have a 99 gts, and have has a/c worked on over the past few years under warranty as was not cold? I have had the compressor, conensor, all lines and o rings replaced, and still no cold a/c. I put a temp guage in the vents, which should be between 38-48, but car runs at 70 highway and 80 in the city, not very comfortable, any suggestions?? Dealer says it is ok, but it makes you sweat when the a/c is on? The car used to freeze me out before on the first setting, but know it is very warm, especially once you stop for a little bit for lunch or somewhere, and you start if back up, it gets even warmer??
