Mr Hemi Head
with air temps? After installing a 6.5lb pulley and Roe PCM, street tuned for a flat 11.5 (3rd gear) when the air temps were around 80 deg.
On the dyno tomorrow at 10AM, temps will be closer to 55 deg.,relative humidity will be about the same (50%). Viper runs great so I won't mess with the tuning. Just want to compare W/B Commander with the Dynojet and get final HP numbers.
Will the A/F be higher or lower?
Rick
Rick
