After the purchase?
Ron Hickey
Falls Church, VA
The 97 is a great year -- classic blue/white colors, lumpy cam, and strong engines. The 96 wheels are the "weak" ones, but they should not fail in normal everyday street drving; however, the 96 wheels are unsafe for track use. The 97's are fine for street and track use. Assuming that the car has the original Pilot MXX3 tires, be aware that those tires were manufactured in 1996 and are 8 years old now. A switch to new rubber is not mandatory, but you would notice a difference if you replace them. The Gen II Vipers are not rife with major problems. It does seem that many cars of the 96-97 vintage have problems with oil leaks. Possible causes include an oil pan gasket, timing chain gasket or cover, main seals, or a porous engine block. If this car does not exhibit the problem, it could develop it in the future, especially if you decide to change its lifestyle from the garage queen existence it's always known. Another common problem on the 96-97's is the door window rubber, which tends to tear near the top right corner. A warranty would come in handy; otherwise repairs, should these problems develop, are on your dime. If you're buying the car from a dealer, he should be able to sell you a warranty -- if you keep the car for several years, it will pay for itself.
In addition to replacing all the fluids (don't forget tranny and diff), as soon as possible I would also replace the plugs (use stock Champions) and wires (aftermarket Mopar Performance, MSD or Magnecore) and clean the throttle bodies.
BWoodbury
Hawthorn Woods, IL
You have a great start there and Ron's ideas are right on the money. The only other issues I can remember from my '96 were an change to the alarm system (under hood sensor) and the PCV harness upgrade. I don't know if these issues would apply to a late '97 or not, but I know who would. Give JonB At Parts Rack a call...
MiamiJeff
Miami, Florida, USA
Slightly off topic since this is a pre-purchase suggestion, but you might want to run the VIN # through carfax.com just to make sure the title's OK (not a salvage or lemon title).
King GTS
Houston, Tx.
I think you've made a good decision. You certainly thought it through. Post some pics for use when you get it. Welcome.
