Air fuel mixture (where to test)?
mrviper99
Livonia ,Michigan USA
Where is the most accurate and correct place and way to check air fuel mixture? Had it tested at dyno, however he just had a tail pipe unit. Wouldn't it be better to take the reading at the O2 senser in the headers before the cats. Thanks Jeff
Tom Welch
Blairsville, Georgia
The best method is with a unit that threads into an O2 **** in your exhaust system. It doesn't really matter if it is installed in a forward or rear ****. What I typically do is make a pull and switch the a/f reader to the opposite side of the car so that I can get a reading from both banks of cylinders. I have seen Vipers that run leaner on one bank than the other. This is a good method to insure that forced air induction and or additional fuel is being distributed correctly.
Tom
Http://btrviper.com
LTHL VPR
I would highly recommend that you weld in an additional **** to your exhaust system, and use it for measuring 02 using a high quality A/F analyzer/monitor.
We do not recommend that you remove your O2 sensors and replace with the A/F monitor O2. Depending on the bank you use (primary/secondary) it can cause your computer to make adjustments that will not represent real world driving conditions. You can even trigger a code. With over 50 Vipers in our database and over 500 runs, we know a fair amount about the computer on the Viper, how it reacts in almost all conditions, and what can cause inconsistent results.
Call if you have any questions.
-Wayne
