Alignment Specs
jcaspar1
Sacramento, CA
I am gettting my 97 GTS aligned tomarrow and after alot of searching on the subject I decided to go with the following specs:
Front:
Camber -1.50
Caster +6.0
Toe -.03
Rear :
Camber -.50
Toe +.03
Is this a good setup for a daily driven car that sees a few driving events each year? I would like to improve handling in the twisties without excessive tire wear, decreased straight line braking or excessive tracking in grooved pavement. (yes, I know, I want it all
Any comments would be appreciated.
SoCal Rebell
Mission Hills, Ca USA
Just what Tom said do a rear camber of -1.00, you might wanna bump the front camber to -1.75. I'm running those specs (other specs are same as yours) and am very happy with the streetability and she responds better on the track. No noticable tire wear yet.
Marv S
Scottsdale, AZ
STOCK for 97:
Camber -.2 (+/- .2)
Castor +6 (+ or - .5)
toe: +.05 (+ or - .04)
Rear Camber -.5 (+ or - .2)
Rear Castor: +1 (+ or - .5)
The front camber will change ~-1.0 if you pull the shims. Just re-set the front toe and you're good to go.
FirecatF7
