Any Ideas on what could cause this???
got one
Castle Rock
Environment:
Air Temp: 78.5 F
Humidity: 31%
Altitude: 410ft
Vaper Pressure: .3 in-HG
Absolute Pressure: 29.5 in-Hg
Dyno#1 was a wash...due to an error. But as you can see...I should have more HP/TQ...AND my A/F ratio looks way off...
Mod List:
1. Recent head gasket replacment (no performance mods done)
2. Chromally Flywheel
3. TNT Headers, RT hi-flow cats, Dynomax muffllers, 3inch exhaust
4. 3.55 Gears
5. Smooth Tubes
6. K&N Filters
7. MSD plugs and wires
8. everything else is drivetrain wise is pretty much stock
But here is Dyno Run #2
And Dyno Run #3
http://gallery.viperclub.org/showphoto.php/photo/49720/cat/500/ppuser/23731
Thanks all!!!
got one
got one
Castle Rock
Any idea on how I can make those images larger so folks can actually read them?
Thanks,
jasontiff
Austin
Email 'em to my Hotmail account and I'll see what I can do with my FTP server.
jasontiff
Austin
Here go:
triblk6spd
Austin, TX
Man I wish I could help. I am going thru the same !@#$ with mine down at ART as we speak. I sure hope they get a handle on it soon. Maybe a shop rag stuck in the intake?:D I hope you figure it out soon, I know how frustrating that can be.
Schulmann
Canada
The AFR isn't so bad.
The torque variation at upper rpms might be related to an electrical/ignition issue.
- Check your ground points
- PCM connections
- Plugs
- Plug wires
Other than that a good mecanic will be able to verify everything around your engin.
got one
got one
Castle Rock
I'll keep my fingers crossed...
got one
got one
Castle Rock
- PCM connections
- Plugs
- Plug wires
will check those tomorrow... :) thanks!
PhilC
Jackson, NJ, USA
It kind of looks like something mechanical perhaps in the valve train My brother had something similar but his started at around 4000 rpms. His motor had been rebuilt by a bumbling ***** in Illinois (not mentioning any names) so it's not likely relevant. The exact cause would be hard to pin down because he ended up rebuilding everything and then retuning.Good luck.
[COLOR=red said:
Schulmann[/COLOR];2630322]The AFR isn't so bad.
- PCM connections
- Plugs
- Plug wires .
My bet indeed........just this AM yet another customer emailed me that his runability woes were solved by plug wires, even tho tests and mileage would say otherwise.
Plug Wire Age Matters
got one
got one
Castle Rock
Hoping so...that would be an aweful easy, quick and cheap fix...
Jack B
NE Ohio
What you are viewing is not the whole story, your plots are using a smoothing of 5. That alone is hiding the the true curve/perormance. You should get the actual files and re-plot them with zero smoothing, then, we will have a better picture to assess.
Another tip, if they are using the Dynojet brand of a/f logger, there is a built-in (not removable) smoothing that injects a large degree of error. It typically shows a full point leaner, but, that is dependent on how the pre-wot ramp-up is performed. That is probably why the a/f does not show the same issues that the power plot is demonstrating.
The problem is probably some where in the ignition or ground system as has already been stated. It probably is not mechanical since it also happens at a lower rpm, although somewhat less severe.
got one
got one
Castle Rock
Thanks Jack B...I have the original files...I"ll take out the smoothing and see what it looks like.
Also, chatted with Tator this weekend...ordered a new set of O2 sensors...since the originals are in there, it might be the culpret, not to mention that at the very least would be a good time to replace them anyway...i'll let you guys know if that fixes the problem...REALLY HOPE SO.
got one
got one
Castle Rock
O2 Sensors didn't work...taking into shop...car has been down for over a month and the driving weather has been perfect...time to let the pros check it out and hook it up to a computer and such...
jasontiff
Austin
I have an OBDI scanner if you wanna play Viper Tech at my house...I even bought a "Viper Specialist" patch on Ebay!
I wish I was joking...sadly I'm not.
got one
got one
Castle Rock
You guys stay up way too late. How did the brakes and rotors work?
Brakes and rotors worked fine...actually stops 100% better than before...WOW!
MIGHT try and do plugs and wires tonight...not sure how to troubleshoot wires though...or plugs outside of just replacing them all...
got one
got one
Castle Rock
I have that same patch...too funny.
Ya, not even sure how this scanner would help in this case...perhaps....is the device portable by chance?
Jack B
NE Ohio
With the right scanner you can look at injector pulse width. Take a wot third gear road pull and see what happens to the injectors. That way you can at least rule them out and start concentrating on the ignition.
What seems interesting is the fact that the miss does not seem to influence the a/f. Typically that type of miss will drive the a/f lean. Very definitely a bad plug or wire would show as a lean spike on the a/f. One problem you have is the built-in smoothing of the Dynojet a/f sensor/software, that makes it hard to seen a/f deviations.
99 R/T 10
Enterprise, AL USA
Jack,
you need to set aside some more time in your life to hang out here more and give input. :2tu: Try to show more than once every other week................. :D :D :D
Big Mac
Austin, Texas
I have a good scanner too, not sure what it will show on your 94. Most of the time you can't see damage on a plug or a wire so swap them all out.
Where did you dyno?
jasontiff
Austin
I talked to Ryan today and I believe he chased down the problem. He swapped plugs and wires over the weekend and voila...problem solved.
got one
got one
Castle Rock
Yup...had over 30k on the plugs and wires...upgraded to AB's wires. Man the car woke up after swapping out the wires! Taking to dyno next week to see how it does.
sham5430
