Anyone have these used parts??
Chris1
Drums, PA
Before I contact Jon B., I thought I might see if anyone had either of these laying around. Car is a 1996 RT/10; first part is the rubber grommet that the screw/bolt goes through to attach the rear of the window curtain to the door; the passenger side grommet was missing when I got the car, and the Wizard says you have to purchase the whole piece ($$$$) to get the grommet; the 2nd part is the plastic cover that is on inside top of the driver's door; I didn't check with the Wiz on this one, but I thought I'd check to see if someone had a used one; I need 2 of the screws as well, as they fell out since the piece is cracked around where the screws attach to the door; it looks like the seat belt guide may be a part of that as well, however that piece is not cracked.
Thanks, Chris.
Puntacanaviper
