Are these any good?
agentf1
Phila Suburbs
mine has the k&n`s already.are the s&b about the same as the k&n?
They look almost identical except the pleats run in different directions.
I have the S&B's and between that and the smooth tubes I noticed a slight improvement. It could have just been the first time I drove it with the new filters we had much cooler air which I know helps alot but regardless I felt a difference.
FE 065
MI
The 'horsepower gained' difference between different brands of aftermarket filters probably isnt enough to worry about. The S&Bs are already suspected by some people of allowing just a little too much dirt pass thru the filters.
Besides, you need to get the exhaust working better before worrying too much about the inlet end. If the exhaust isn't maximized, the demand on the inlet end will continue to be minimized.
