GTS-R 001
Does the Autoform rollbar with the removeable side pieces prevent your access to the emergency release handles in a GTS?
It is tight, but the emergency release handles still work.
JD
We just finished our rollbar w/ side bars. We had stopped building them, but we just had a vehicle in which we were able to redesign one in. So, they are available now.
Now the main question was in regards to the pull handle for the door release. As stated some cars do allow you enough room to pull the latch, but others do not. In those cases, Mark is correct you will need to cut down the latch itself, and I believe only 1/2 an inch is needed.
