battery cover screws
SBMIANO
What tool is used to remove these nightmares. Looks like a star wrench but was told that it is a "special Tool"
Any thoughts??
Scott:dunno:
fqberful
Central FL
Any thoughts??
Scott:dunno:
Just an every day TORX .. I forget the exact size but it's a common one.
redtanrt10
Dana Point CA
They are torx screws. You've got many more in addition to the battery box (interior trim, skid plates, etc. etc). You need to add a set to your tool box and you need a set of torx drives to use with an electric reversable drill. $20 -$30 for both sets? Use a drill and bit on the battery box or it will take you 15 minutes and you'll have some pretty sore forearms, they're in there tight and long.
ulllose
Brunswick, Ohio
When I took my battery cover off for the first time I used a torx on a 3/8 drive rachet.......after 10 minutes on 1 screw I could not believe how long these damn things were, so I grabbed a drill..................................
Shandon
Northern Kentucky
Yup get out the Dewalt and the torx bit. Have fun:omg: I striped two of mine but ohh well. They are a little easier after removing them the first time.
Racer Robbie
Guilford, CT-USA
A bit of advice here depending on what climate you live in. I would coat the threads with a little Never-Seize as they tend to get crudded up and come out with a little difficulty the second time around.
