Battery question
V10 MOJO
Youngstown, Ohio
i reviewed some previous post regarding battery life and etc. what is th ebest recommended after market battery?
Diablo Joe
Lakeland,Fl
How about a lighter battery.Those mentioned above probably weigh 45 lbs.Is there anything lighter? Say about 20 lbs.
Joe
MadMaxx
Simpsonville, SC
When you replace yours, clean the battery tray with bakingsoda/water and scrub the rust/dirt off. Hit it with a hammer tuff rustoleum (black). Then put the battery back in
MM
GTS Bruce
Orchard Park,NY,USA
Autozone Optima red top.Might have to stretch your battery tray a little like I did since it is a tight fit.Used a bottle jack for a little stretching.No two battery boxes are exactly the same and some are a little to tight.No vents,no leaks no acid fumes or spillage eating away at your car. Bruce
MES
Sarasota, Florida
Stock battery (Mopar) weighs 40 lb (according to my bathroom scales) the Optima 75/35 is 33 lb I have the 75/35 and it fits fine.
You might be surprised when you check a wide selection type battery comparison...recently read one that at least reaffirms my own prejudice...Die-hard Gold hard to beat interms of availability (to purchase AND to return for warranty), price (about $80.00), CCA, size/fit, length of useful life in OUR Vipers. Am NOT recommending this for track as I really do NOT know about leakspill status...noting that we have them in 3 of 5 Vipers that see street usage with NO problems at all.
95Viper
Phoenix
Hands down, Optima. Closed cell about $109 at Autozone. I bought sku 260-3760 red 75-35. There were two models exact size but one had higher cranking amps. I paid the extra $10 and got the better one. Fit in perfectly.
