I went to check on my 06 vert in storage and found the battery to be dead. I bought the car new in may of 07 from a dodge dealer.
So when I removed the rear carpet to take out the batt. I found all the star screws were striped. I finally removed they, (2 hours) and found a chrysler battery that I am not sure is factory. The manual says the battery is sealed and this one has the pop off caps for distilled water. Is this factory or did the dealer change it out?
By the way put a two hour charge on the batt and put a trickle charger on it. Should of done that in November.
I went to lowes and purchased the 6M machine bolts with a hex head on them so I can now use a socket on them to remove the plate.
Any feed back about the battery would be appreciated.
