CHAD
What are the largest wheels and tires you can get under an SRT without modification or unattractive offsets? The rear tire is the largest radial made and will mount on up to a 13.5" rim. Will this fit? Also, the CC runs 11" front wheels (14" rears). Will these fit up front and if so, what tire to run? I'd love to run the 315/30-18 up front on an 11" wheel (almost the exact same diameter only wider) and the stock 345/30-19 on the 13.5" wheel.
Any input is greatly appreciated.
Chad
Chad
