brake bias fix?
Tom F&L GoR
Wappingers Falls
Anybody know what this is or how it works? Thanks.
Rippie spring and click C4/C5 brake bias spring
From the website:
On the C5, the DRM Bias Spring easily installs in the junction block, and on the C4, it installs in the front of the master cylinder.
Good things often come in small packages. A lot of thought and successful racing experience went into the design of the DRM BrakeBias spring. Easily installed, this spring effectively puts more rear brake into your Corvette, giving you shorter stopping distances and more equalized front-to-rear brake pad wear. Also by having the rear pads do more work, front end nose-dive is reduced. This results in greater stability and vehicle control under extreme braking.
1987-96 Corvette ABS 10-100 $13
1984-86 Corvette non-ABS 10-101 $13
1997-01 Corvette 10-102 $13
erikguilefuss
