Brake light switch (97 gts)
ls2ws6
Ok so I have this 97 gts that the brake lights stay on after you shut it off.
So I go to change the switch (which autozone has for 15 bucks)
it is easy enough to remove by disconnecting the wiring harness and a 30* turn in the counter clock wise direction.
The problem is I cannot get the new sensor to attach to the bracket again, the manual does not say much anything about this.:dunno:
Has anyone had any experience with this, Im sure im not the only guy whos had this problem, and I have already broken two new sensors trying to install/twist them on to the bracket
Alex
Andrew Prause
