treynor
Burping a \'01?
I recently installed a Fluidyne radiation in my '01 RT, and I've had funny cooling anomalies ever since -- the heater will stop working, then start again; the temp will rise to 230, then drop to 185 within 5 seconds. I'm assuming this is because there is air trapped in the sytem -- I've got two bleeder valves, and each time I check them they have some air to release. From inspection, it appears that the '01 cooling system works the same as in previous years, and that the burping approach used for previous years (open surge tank, squeeze radiator hose, etc.) should work on an '01. Can anyone confirm or refute?
Thanks!
Ben
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by treynor on May 26, 2001 at 19:23</font>
Thanks!
Ben
