busted an A-Arm! Anyone ever done this before?
Joseph Dell
Atlanta, GA 30338
was working under the car and was checking out the suspension. look at the cracks on the lower A-arm. how the heck did this happen?
Blue Pilot
N.E. Ohio, US
I also see the HP numbers you are putting down. Although there should be no twisting force an the a-arm itself, funny things start happening when you more than double the HP on parts that were not engineered to handle it.
However, I would guess it came from a bad cast.
J
Joseph Dell
Atlanta, GA 30338
Here is a better look:
I see three sets of cracks. are they just surface or are they real? the other side doesn't have any of these...
JD
1TONY1
Dalton Ga. (Chatt. Tn.)
Two of them "look" like casting marks....the middle one looks like a crack right where the casting mark would have been. Maybe this is why we gring the casting off the side of a connecting rod....it is less prone to break in that area.
99 R/T 10
Enterprise, AL USA
Looks like it could be a crack (at least the middle one), but it also looks like a casting mark on the the high point of the A-arm.
Qualitywires.com
Louisville, KY
Jdog,
that is what happens when you don't call your bud..bad karma happens. Man! You better lay off those dounuts! LOL!
J
Joseph Dell
Atlanta, GA 30338
Left rear. 17000 miles. 1000rwhp car, though.
I'll replace it this week. Big thanks to JonB for going the extra mile to find me a used one and sending it fast!!
JD
Nadine UK GTS
Bath, Somerset, UK
Hi Joseph, yeah I've had them crack on my '97; several years ago and Jon B came to the rescue with take-off arms for me. Mine were cracked around the rubber bushed / frame ends though, also I discovered a toe link cracked right through. I check mine regularly now, initially the cracks were hidden by the paint, it wasn't until I scraped the flakey paint away I discovered the horrors at the time!
Camfab
SoCal
They look like casting marks, but if your going to change it out you should have the part magnafluxed. If it indeed is cracked, I would take a hard look at all your suspension components.
Atom
