Can and/or should I install a window kit to a '94 RT/10?
Mopar Steve
Newark DE
Re: Can and/or should I install a window kit to a \'94 RT/10?
Order the viper mania windows. They install just like factory but give you a regular hard window, instead of the stock "jeep" widows. best upgrade I've got!
joe117
Maryland, USA
What do you mean by "window kit"?
Sniper
Viper City, Iowa
I did see one place that will do this a long time ago, but I don't remember who it was. I do remember it costing around $6,000.00! A little much but it would be nice.
Jack B
NE Ohio
Another suggestion - I had Northwind windows, they worked well. I have not seen the V-Mania windows in person, however, I opted for the Northwinds, because, they appeared to have a larger opening.
My first set came in with a minor defect, they sent me out a new set before I sent back the first, very nice people. Installation for anyone shouldn't be more then fifteen monutes.
Roland L-Ocala FL
Ocala, FL USA
Autoform windows and roof system are very nice, but if you only want windows, we got the V Mania ones, and they have worked out very nicely. They install right where the factory windows go in the inserts in the door, and take very little time to install, and you can use the same window bag that the original plastic and canvas windows came in. They use a bayonet mount just like the original equipment ones, but you get much better visibility, and a very tight fit.
Don't overlook Autoform either, the complete window and roof package really changes the look of the RT/10, almost more like a GTS as far as head clearance and roof space.
It all depends on exactly what you want as a finished product.
GCHDEALER
MARIANNA,FL,USA
Vmania all the way. Great look with their hard top. Biff is a great person to deal with.
joe117
Maryland, USA
There is a set of Mopar sliding windows on ebay right now. You can probably get them for a few hundred $. I have a set on my car. They are a big improvement over the zip outs and you could save a bunch over the aftermarket. I know they probably are a poor substitute but I thought I'd throw this in.
bigr1
Pittsburgh, PA
got a picture of the mopar windows? how do they fit? how do they look?
Steve Ferguson
Burr Ridge, IL
With ViperMania and Northwind there is no installation. They fit right in the holes already in the door.
The kit referred to above is expensive and from what I saw cuts your Viper up quite a bit.
