Big Al
I am in the middle of changing the motor mounts on my 04. Driver's side was easy but I can not get the passenger side out past the exhaust. I have jacked up the front of the motor about 3 inches, bent the heat shields and no matter how I rotate the mount it does not want to come out. I even tried unbolting the old mount from the cast aluminum bracket but it was too tight with the bracket floating loose. Woodhouse says that I do not have to remove the exhaust manifold but has anyone got any suggestions for me. I even thought about leaving that old mount in and changing the driver's side and the transmission mount but I do not want to it half way and I am too stubborn to give up.
