KaiPL
Can you change out just 5th and 6th gear without messing with 1st through 4th?
I like the ratios for 1st through 4th, but would love to make 5th and 6th gear a bit more useful.
I think that the perfect set up would be to make the current 5th gear the top gear, and replace the current 5th gear with a gear half way between the current 4th and 5th gear. That way, I could tighten up the ratios between the higher gears, and won't get the bog when shifting between 4th and 5th at high speeds.
I know absolutely nothing about transmissions. Is it possible to just change 5th and 6th and leave the rest alone?
