If you're running stock boost 3.55 gears are perfect 1/4 mile gears for your combo and put you near readline in 4th when running through the traps, while also allowing the use of 6th gear on the street. Since you have forged internals, you'll probably end up increasing boost in which case you'd probably want 3.33s since 3.55 will limit top speed in 4th to about 135-136, and you would likely exceed that with more boost. . Do youself a favor and also upgrade to a Quaife at the same time. You can purchase an entire replacement rear end completely set up with new gears, quaife, bearings, etc, swap it in, and then return yours as a core. I unfortunately took a more expensive route and initially went with the 3.55 gear upgrade with the Paxton, my car is presently is back at Woodhouse for a Quaife upgrade along with a few other times. Looking at your other thread, the addition of PS2s and a DLM intercooler and larger pump will make a world of difference in that Texas heat. . Good luck.....
