Check engine light !!
Gerald
Near Tampa Bay
Make sure you hooked the small wire back up by the end of the tubes where it goes into the air box. Many ppl forget to hook that back up, if you do, check engine light will show up..
Also check the wires in the throttle body area, make sure you didn't jiggle one of them loose..
That should do it..
Gerald
BlackACR
Rowlett,Tx
Also, make sure the tubes are tight on the air box and throttle bodies. If it ***** any air after the sensor it will kick a light.
sham5430
