Mopar-man
On a 2006 SRT with factory run-flats what is the best tire pressure for cold weather storage?
FACTORY CALLS FOR 29 PSI ALL AROUND.
THIS IS WHAT I FOUND TO WORK BEST
PSI = STREET TRACK
ZP = 30 PSI 32 PSI
ZP = 30 PSI 32 PSI
I disagree with Yellow's statemenets. First off, the runflats ****. But with that being said, they work better in my opinion with around 29-32lbs. They grip well around the racetrack with less pressure. They launch better at the drag strip with less pressure.
On the street, if you run 32lbs and up, the car seesm to track better over grooves, but I still would rather have grip. I run 29-30lbs year round but will be switching out to PS2's soon and will then have to re-test. Just my .02
