Creampuff --- not!
Frank 03SRT
Somewhere in Kansas
I believe these are fairly good numbers, right? First time on the dyno with a car with 1043 miles.
1st run: 418.6 HP and 453.0 FTLBs
2nd run: 430.2 HP and 471.9 FTLBs
Only has smooth tubes and filter. I knew this car was better than the 00 I had because I can't keep the tires on the ground when I floor it in first on a coast. Man am I happy (unless someone tells me this really is creampuff material).
Next, on with the Corsa 3"!
Russ M
LA, California
It all depends on the dyno jet facility you go to. From what I saw there are no miracle vipers, they all pull about the same hp. The only difference is that some go to dyno jets that pull low numbers, other go to ones that are on fantasy island.
Not to burst your buble or anything but those numbers are definatly way too high for a stock car. Go to another dyno facility, to get the facts.
F
Frank 03SRT
Somewhere in Kansas
Gerald, rear wheel. The operator said add 15% for engine. Someone else said 12%.
Future GT: Yes. A lot of people think the 00 and 01s are weaker than earlier years.
