Custom Gen-3 Dry Sump System, Who is interested?
Cape Coral, FL
Hello All,
I am posting this just to gauge interest in a system like this. Replying to this is by no means a commitment, but I want to know who WOULD purchase a system like I will describe below, if they had sufficient time and/or money to prepare for its availability.
What is a Dry Sump:
In a nutshell, a Dry Sump is the Be-All, End-All of oiling systems. Oil Starvation is a thing of the past, totally. A Dry Sump consists of oil lines, a new oil pan, a new pump, and a big reservior. The Oil pump is actually 6 oil pumps in one unit- 5 for "oil scavenging," and 1 as the "pressure pump." The scavenging pumps **** all of the oil out of the engine and put it into a reservior. Due to the reserviors shape, it can not loose its "feeding ability" to the pressure pump- the main cause of starvation. The pressure pump is what lubricates the engine. These systems hold upwards of 20 quarts of oil, and can feed an engine in virtually any condition short of full-out upside-down. As a person who is dumping massive amounts of money into my engine this winter as many as you already have already done or plan to do, it is certainly worth its large entry cost for a bulletproof system. There is a reason these systems are used on virtually every professionally built race car on the face of the planet. As an added bonus, Dry Sumps produce a vacuum inside of the engine, which will increase the HP of virtually any engine it is bolted onto. Whether you plan to drive on the track where a system like this is a no brainer, or if you drive ******* the street... or even want some serious peice of mind, these systems are it. Hearing about Comp Coupe oil pan equipped SRT's and CC's blowing enignes on the track is what made me seriously look into this modification.
Information:
I am looking to work with a Dry Sump designer in an effort to produce a Dry Sump System for the Dodge Viper Gen-3 engine. There ARE indeed systems currently on the market in the $5500.00 range. However, the problem as I have discovered is that the A/C system must be removed in order to use these on a gen-3. From my perspective as well as my Customers, this is NOT acceptable. On a Comp Coupe it is one thing, but for a track car also driven on the street, it means a worlds of difference. I plan to produce a kit that is fully integrated into the Gen-3 cars, much moreso than what is currently available. I am looking at way to keep the A/C intact, as well as simplify the system, such as designing a Dry Sump tank that can be mounted towards the front of the car, or at a minimum, not interfere with trunk space. Also, I am exploring ways of implementing the OEM filter location, as not to have "dead" parts hanging off of the engine not used. Any of you who know me well, know that I frown HEAVILY on anything that does not LOOK like it could be factory.
Pricing and availability:
As stated above, current Dry Sump systems WITHOUT the tanks retail for about 5500, plus the additional cost of oil lines and sump tanks (+1000). My target is to produce a system that has the qualities and changes listed above, INCLUDING a tank and a Core or Modified timing cover if neccessary for the SAME price range of 6500-7000 maximum, COMPLETE, ready to install. No ********.
If I can come up with a design that works as I intend, I would require a 25% downpayment, with the balance due at completion, right before shipment. Time period goal is early Spring, Feb-April timeframe.
Please let me know if there is any interest, or POSITIVE comments. Do not flood this thread with BS I do not want to hear about. If you think it is to expensive, then it is not for you- I do not need to know that, just dont post. These parts are VERY expensive and time consuming to make, and I will not be making much of anything on these initial kits, IF I can even make something work...I am just looking to cut down the costs of manufacture, so such a kit can even be brought to market.
Cape Coral, FL
Hello Guys,
Just an update: I think I have successfully come up with 3 possible solutions to the current problem of A/C interference, all of which COULD work, depending on the willingness of the fabricator of course. I also think I have come up with a good location for the Dry Sump Tank. I am exploring one other possible solution at this time.
The only downside is that it is looking like a complicated install. Not necessarily difficult for a decent mechanic, but some components (like the front bumber) may have to come off. On the upside, this system will look damn near factory installed, and it does not look like anything will need to be permanently modified.
If I can get a few more names, I would be more comforable...LOL. But, as long as I have at least 2 other hard-core people to make it happen, it will.
Racer Robbie
Guilford, CT-USA
I do not see that the things you mention above would be a problem. I am still sitting on the railing waiting the outcome of the final price. Great Job!
INSOMNIAC
Europe
Will it look something like the GEN 3 Dry Sump kit West Coast Viper offers?
It's an expensive mod but I might consider it depending on how the cost turns out..
Cape Coral, FL
INSOMNIAC- Well, that depends VERY much on the final mounting location of the pump. It could range from looking similar, to looking flat out different. One thing I do aim for is putting together a much more complete system than the above. that system includes only parts from the pan to the pump... what about the other half of the system from pump to engine?
Cape Coral, FL
Just posting an Update guys...
I have by NO means given up on this project, however I just want to alert people that it has indeed changed direction- for the better I might add.
Basically, as of end of last week, I had a flat out wonderful idea. So good in fact, that it didnt hurt very much to scrap the ORIGINAL Dry-Sump idea, even with Big Bucks already invested. Win some, lose some I guess. I see a very large market if I can make something available that fulfills the original guidelines. It must:
-Retain the AC
-Retain the workings of the OEM oil system such as flter location, etc
-eliminate starvation issues
-not interfere with storage space
However, as I have found out, it must also be ATTAINABLE. People are not going to spend 10,000 bucks on a dry sump- period. And unfortunately, with an AC add-on, thats what it was going to cost...with a weight penalty and a slight loss of storage space too.
Well... I had an idea. A freak'n great one at that. It will fulfill ALL of the requirements from the original conception, but best of all, by design, it does not interfere with A/C, and will get rid of a couple MAJOR costs associated with going the other route- all with the same results. By less, I mean this is looking to be a SUB- 5 grand upgrade- perhaps even into the 3-4 range!
I am not spilling the beans yet, only a few people even know what I am planning. I have not ever seen a system like this on the market, and I am not giving someone the opportunity to run with it.
I will update as soon as I can!
Viper X
I would be interested too.
rcl4668
Oregon, USA
Final GTS -- sounds interesting; I spoke with my local Viper tech who also confirmed that the comp coupe oil pan is not a total fix; rather, onthe competion cuope the dealership runs they have also intalled a dry sump system. Please keep us posted. Also, please make sure you contact a good patent attorney; it would be a shame if your truly original idea was copied by your competition.
/rich
Cape Coral, FL
/rich
Rich-
Yes, that is the main reason I have been so heavily into this project. The CC oil pan is NOT a complete fix for the problem, as some people have found out.
I very well may contact a patent attorney once I have a couple systems produced, available and proven.
KaiPL
Salt Lake City
[quote
Rich-
[/QUOTE]
Once the systems are "produced, available, and proven," it is too late.
As soon as the system is "available" it's no longer patentable. So, don't offer to sell any of these before you file the patent. You have to file the patent BEFORE you make it available to anyone other than yourself. You also have to file the patent BEFORE you disclose it.
Actually, you should probably file the patent right now. Folks always think that you need a working prototype and you need to have all the bugs worked out before a patent is filed. This is not true. Patents cover inventions. Inventions are ideas. As long as you can provide enough information in the patent application to describe the invention and enable other people to practice the invention, you're covered.
rcl4668
Oregon, USA
Final GTS --
I second Kai's remarks regarding patent issues. Please protect yourself.
/Rich
Cape Coral, FL
Thanks for the comments guys.
Kai- By available, I mean to myself ONLY. I just do not want to waste the time and money with Patents if I discover there is a fault in the system I dd not anticipate. I cannot possibly see how, but I would rather have a working system first.
Quick2tr- Nope, it will not require the use of the CC oil pan. it "could" use it, but it would be more cost effective to use the OEM pan. a CC pan owner could pop theirs off and sell it for 1250 or so used, and pick up a new OEM pan (if they dont have their original) for around 400 or so.
INSOMNIAC
Europe
If you could come up with a complete Dry Sump or "Dry Sump Like" system for GEN 3 and still be around $3-4k range, it will sell like what K&N filters and Corsa Track exhaust used to. Sign me up for one.
Good luck and keep us updated as you try this new system of yours.
:2tu: :2tu: :2tu:
