Dashboard light question
wikkid
It seems my bulb that illuminates the odometer in my car has gone out. Has anybody replaced this bulb, and how difficult is it to get to?
Roadrunner
You have to pull the dash trim off, and probably the steering column shroud, and then you can remove the cluster. The cluster lamps can then be swapped out easily.
W
wikkid
Any pointers on pulling that dash panel off. I thought you had to pull the whole dash off. I will check some threads and see if i can find ant directions.
Thanks.
Black Moon
Knoxville, TN
Unfortunately you do if i remember correctly but it's not that hard.
First remove the console. Then the radio bezel (allen screws). Drop the steering column (2 bolts). Then pop the dash trim off. Be careful at this point (i cracked mine). Then a few screws for the gauge cluster itself. You may have to remove the rear bulkhead between the seats if memory serves me right. I've seen a write up somewhere on the site but can't remember where.
It's not that bad just a little time consuming. Good luck.
No members online now.
JpKL
