eabrillon1978
How to DIY Roe Dual Walbro Pump Installation For Gen II's
I ran into some fuel issues when going to the 10lb pulley setup on my 98 GTS with a 2.4L Roe. I purchased this dual 255 Walbro kit from Roe last year in case I needed it and now I do. Here is my little install thread to use as a guide if you decide to do your own one day. I didn't install any fancy AN lines or fittings just used what was in the kit. It took me about 4 hours to do everything from removal to install. I still have some wiring to do and testing the pumps, but will post that after I finish. Some of the pumps in other years are different. Mine used a Walbro, some use a Carter. You may have to do some things different, so use this as a guide. Not sure how many baskets are the same as a 98.
If anyone has any tips.. please feel free to comment. I'm pretty much finished up, but maybe it'll help the next person.
Tools needed:
Drill
Drill Bits 1/8", and 3/8"
Hole Cutter 1 3/4"
Channel lock Pliers
Pliers
Small Screw Driver (flathead)
Regular Phillips
Large Flathead
Sand Filled hammer
Dikes
Needle Nose Pliers
Scribe
Dremel to cut the inserts for the clamp.
Other items needed
Small wire ties
2 band clamps
JB weld
Here is a pic of how the pump sits in a GTS when you get the cover off. I forgot to take a pic of it when I first removed it, so you get an after shot
- the red and black wires will not be there when you first remove it - Remove the clamp with some needle nose pliers. I just twisted it around a bit and it broke apart. The large black vent hose was removed with some channel locks, not the easiest hose to remove, but to get it off, lightly grip the hose and move it back and forth. The fuel line you just pull back the blue plastic clip and squeeze it with your finger. The lock will release. For the wire clip, just slide the red locking tab and then squeeze the top clip and it'll release. Take a large flathead screwdriver place it on the nubs on the ring of the pump and hit the back of the screw driver pushing the ring in a counterclockwise direction with a sand-filled hammer to prevent any damage to the ring. After removed you have to angle out the pump slightly to avoid damaging the float.
A little side note, before you pull the pump out, blow off the top to remove any loose debris so that it doesn't fall in the tank. I just used a little air blower. Then put a rag over the hole to avoid any debris going in the tank after removal.
Shots of the pump removed. Mine was a little dirty on top , just plugged all the hose connections and rinsed it off to clean it up a bit.
Good as new!!!
Here is the kit from Roe. It comes with everything you need except for 2 band clamps, a couple of wire ties, and JB Weld. It's complete other than that. The primary pump will function as the stock. The secondary pump connects to a switch that activates with at 3lbs of boost.
The instructions were not really complete due to variety of different pumps out there, but with the basic info and a little help seeing images from peoples post on there fuel setups, I was able to figure it out how to make it all work.
First step is to remove the float by taking off the black clip and then gently removing the rod with a scribe
Remove clamp from the black hose inside the basket that connects to the the fuel pressure regulator. I used some needle nose piers to kind of twist and break the clamp. Be gentle because the end of the pressure regulator is kind of small and you don't want to break it.
Pull the top off by inserting a small flathead on the locks on the sides. There is 3 of them. This was a little tricky but it came off eventually. Once you get it up a little, remove the connector from the bottom and then pull the top off.
After you pull the top off, grab the wire connector. Remove the two center wires for the connector. These go to the sending unit. When looking at the terminal you will notice there is some numbers stamped. I just marked the wire with some dots so I know the location. To remove them, pull out the green clip with some needle nose pliers by grabbing the center section and pulling out. This will give you access to the release clips. Use a scribe to lift the tabs are release the clips, pull the 2 center wires out from the connector. Then pull those wires out of the little hole they run through from the basket.
I guess there is a limit for pics for each post. I'll post more in a bit.. Have plenty.
Tools needed:
Drill
Hole Cutter 1 3/4"
Channel lock Pliers
Pliers
Regular Phillips
Large Flathead
Sand Filled hammer
Dikes
Needle Nose Pliers
Scribe
Other items needed
Small wire ties
2 band clamps
JB weld
Good as new!!!
