Actually...you are ALL wrong. LOL
Gen-2's use 9006 Low Beam, and a 9011 High Beam. Dont believe me? Think that Booklet is right? check for yourself and see.
Gen-3's use a AC-D2S DIS, not a D1S DIS. They use this for BOTH Low beam and High beam. There is a shutter in the projector housing that manages the two. That is the "thunk" you can hear when switching to high beams. The inner-most bulbs are NOT high beams, they are combination back-up beams (in case the DIS extinguish momentarily), Flashing (passing) lights (again, if the DIS go out, you lose high and low- they need a backup) and lastly, they serve as running lights for canadian cars. DIS lights cannot be used as running lights.
