Do the SRT-10's have cast or forged pistons?
dwhitt
Glen Allen, Va
Do the SRT-10\'s have cast or forged pistons?
I assumed the Gen 3 motors are still "creampuffs" but thought I would check.
Snakester
Morgan Hill
Re: Do the SRT-10\'s have cast or forged pistons?
From and earlier VCA discussion:
Ken wrote:
The newer cars use a cam with the same lift and duration as the earlier years, but the valve overlap is reduced from 66 to 60 degrees. This took some of the lumpiness out of the idle to reduced NGR (Neutral gear rattle) and improved emissions. The greater overlap of the earlier cams probably explains part of why the earlier cars respond better to exhaust mods (plus they also had poorer flowing exhaust manifolds to begin with, so there was more to gain). This change cam change made the newer cars 'creamy smooth' compared to the earlier ones.
Coincidentally, the pistons went from forged to cast as well. The cast ones are lighter and actually free up a little HP in theory, but don't have the toughness to take more than about 5-6PSI in boosted applications since the ring lands are much closer to the top of the piston. Generally not an issue unless you are considering a high boost application.
DCX was making the Viper a better car overall, but not necessarily better for heavy modifications later on.
But nevertheless, there are some pretty quick "creampuffs" out there with the Hypereutectic cast pistons, and we can expect to see many very fast cast piston SRT-10 Vipers coming out as well, regardless of them not having stock forged pistions.
-Dean.
treynor
Redwood City, CA
> now why the hell would they do that?
Emissions, apparently. The cast pistons expand less when heated, allowing the car to be built with closer toleranceds. It's still pretty irritating.
iwantaviperbad
Shreveport, LA
now, remember this, there are no stupid questions, only answers :) so, bear with me, as i have almost no mechanical knowledge:
why can't you just replace the cast pistons with forged ones ?
99 R/T 10
Enterprise, AL USA
You can, but you just bought a $80K Viper. Now you want to put another $4000-$7000 into pistons? Warranty is gone too.
Vipermed 97.01
Tampa Fl. USA
Emissions, apparently. The cast pistons expand less when heated, allowing the car to be built with closer tolerances. It's still pretty irritating.
Actually the reason they went to the Hypereurectic piston was due to the fact they seal the cylinder walls better thereby reducing blowby.Basically the same reason the Z06 is using these pistons also.They are not to be confused with the cast piston of yesteryear they are actually pretty resilient, there downside is the short ring land which does not do well under extreme cylinder pressures with boost above 5psi
sayed ws6
