Does anyone know how to adjust side windows? 06 coupe
8mywal8
Does anyone know how to adjust side windows? 06 coupe driverside window make a lot of wind noise. Any ideas? Its not the mirror.
V
Venomiss
Guest
Not under warranty? Are you sure its the window and not the trim sealing properly that makes the noise?
Make sure and compare your drivers side to the passenger side.
See if the trim hits it in the same places inside and out.
Sounds like you are not alone:
http://forums.viperclub.org/srt10-srt10-coupe-discussions/601747-window-wind-noise.html
Maybe someone has some other ideas for you to fix it. This might be a possible solution for you to try:
http://forums.viperclub.org/srt10-s...ndow-auto-down-feature-when-opening-door.html
mogocar
