Are you having problems with your door poppers, I was just curious because I just fixed my door poppers on my 95. They were not opening on the first push of the button. The problem was the cable's in both doors needed tightened.
The problem may be my fault. May have knocked off the clip that holds the connecting rod from the door lock switch. Door will not unlock. Will let you know what I find.
Popper was working pretty well - was trying to improve it...."if it ain't broke....
