driveline loss formula..
Eddie N
Bakersfield, CA
even though no one agrees on one driveline loss percentage, for the sake of my question, lets assume its %15...
what is the correct formula for measuring a flywheel horsepower number from the rwhp figure from the dyno?
ive seen:
rwhp*(1.15)
and
rwhp/(.85)
both result in totally different numbers...
thanks,
- eddie -
onerareviper
Pittsburgh, PA, USA
I remember reading another post on this topic, and the conclusion was:
rwhp/(.85)
Some legnthy explaination was included, but my memory is sh*t..
Later
HP
Little Rock,AR,USA
Another way of looking at it, is to think of the equation as
driven only one way, from motor to rear wheels. The motor, or
flywheel, loses 15% before it reaches the rear wheels.
So 100fwhp-15hp=85rwhp - the 15hp comes from 15% of 100fwhp and the equation is correct fwhp=rwhp/.85
If you start from the rear wheels 85rwhp and add 15%, or 12.75hp
you would get 97.75fwhp. which would be incorrect. This would be
represented by fwhp=rwhp x 1.15 and is wrong. HP(Hugh Perkins) rwhp?
Hostile
upstate NY
Correct formula
200FWHP less15%=170RWHP to return calculate 170/.85=200
works all the time,divide by the reciprocal
Skeeter
HP
Little Rock,AR,USA
Ok, let me take a stab at it. I've never seen it explained, but
looking at it, the explaination seems to be in a simple mistake
of setting up the problem. This is best explained by setting the flywheel hp(fwhp) at 100. So if you lose 15% in the drive train, you have 100hp-15hp=85hp Here you can see that rwhp=fwhp x 85% or fwhp=rwhp/85%
But when the mistake of thinking you can add 15hp to 100rwhp
to get 115fwhp is made, the equation changes to fwhp=rwhp x 1.15 Because, there, you are adding 15hp not 15% and you no longer have the right percentage. 100 is not 85% of 115. Its kind of like an optical illusion, it plays on faulty wiring.
ViperGear
