ThinkingViper
- Joined
- Apr 30, 2003
- Posts
- 25
- Reaction score
- 0
I drove a 96 RT/10 today, and have a few questions about what I observed:
1) VIN on inside of windshield does NOT match VIN on inside of drivers door. The inside drivers door VIN is a manufacture sticker type, the VIN on the windshield is a metal type plate/etching. The Sticker VIN on the door also held information regarding weight, manufacture date, and had a bar code. Owner says he bought the car new from dealer. What would be the reason to have different VINs on the door? The VIN inside the windshield is the VIN on the title. I ran a quick check through carfax, and 2 records are found. I'm hoping someone can run the complete carfax test for me?... pretty please
2) When removing the coolant overflow pressure cap, there was corrosion on the inside of the cap and bottle. There did not appear to be any fluid in the overflow pressure bottle. Anything to be concerned about?
3) After taking the car for a 10 minute test drive, there was liquid coming out both mufflers, the liquid appeared to be water. Normal?
4) The heads on this car have NOT been fixed. I understand this is a 'when' not 'if' repair and that I should expect no more than $2,000 to fix (car has no warranty). Could this fix cost significantly more than $2,000?
Of course, I would never purchase this beast without a certified tech examining the car, but I would greatly appreciate someone sharing their wisdom with a rookie.
Thanks in advance,
Cheryl
Thanks in advance,
Cheryl
