Hi Everyone,
Things are finally calming down a bit and I'm getting time to work on the kit for the Viper and Ram again. Below is a dyno sheet from some testing I was doing. The boost varied from 4 psi to 5.3 psi throughout the pulls with major belt slip occurring at 5,100 RPM, causing the boost to go back down to 4 psi. When we're finished monitoring and making changes to the belts, we plan to end up at about 6.5 psi with a charge cooler installed.
Just wanted you let you see how the kit was working in development. A 40% torque increase starting at 1,500 RPM with less than 5 psi surprised me a bit. The test car is stock except the air filters and side muffler change (still 2.5", not upgraded to 3").
Regards,
Sean
Regards,
Sean
