Nadine UK GTS
I have read many tech articles of air/fuel ratio versus EGT (exhaust gas temperature) readings, basically concluded air/fuel is best to tune by, but for individual cylinder tuning and keeping an eye on each cylinders temp (motor safety, which is priceless) decent EGTs are great. I searched and found EGT sensors were expensive, there were no kits to cater for 10 cylinders, so I've lived with installing a wideband air-fuel per bank, but always been interested with individual EGT outputs. Sean Roes VEC2 has the ability to trim or add fuel per cylinder, coming to a rest somewhere, pulling and reading the plugs is good to 'see' what's going on per cylinder combustion, but I wandered what my Beloveds 10 chambered heart was pumping under different conditions. There's no way on a power run you could watch gauges for this, but I found SPA (digital gauge UK company) had a duel gauge that had recall facilities...after talks they were interested in helping me out in my quest.
When I was out in USA recently, I was lucky enough to get taken up in a light aircraft, and then after asking many tech questions, handed the controls to fly it!!
As we gained altitude we leaned the motor out, according to the EGT reading, very interesting. So performance and flight inspired, I had some lugs machined with 1/8 BSP thread to take EGT thermocouple probes! Here's the lugs welded on my headers (the headers I had ceramic coated, hense white!)
One of the sensorsenders in place
The headers on the motor
Plane EGT and many gauges!
The plane I was handed the controls to, never flown anything before!
While my headers were off I got these crude 'pickles' cut out:
There's thought on a forced induction motor the pickles could hurt power, so out they came!
