EVAP clicking?
Nadine UK GTS
Bath, Somerset, UK
My EVAP purge solenoid is 'clicking'? Can the solenoid stick on them (my '97 has been laid up for some time)? It looks like a sealed unit, serviceable? All the lines to it and canister and intake manifold are OK. It's set a trouble code, and my "service engine" light is on (I guess due to this). Anything I can do, or do I need to buy a new solenoid?
Jerry Dobson
Lenexa, Kansas
If I had to guess, I would say that it could stick, just like a float in a carb when the gas **** up.
It is supposed to click as it works, but since you have a Service Engine light...Hmm.
Do you have access to a DRB3? There are some utilities in the tool to cycle the Evap Solenoid. Without this it is going to be tough to verify without just replacing it.
Viper Wizard
South Salem, NY USA
Hi Nadine,
Here's a little Info out of my Diagnostic book. You may need access to a DRBIII to pin point the problem.
Name of code: Evap Purge Solenoid Circuit
When monitored: With the ignition key on and engine running.
Set condition: After the arming conditions are satisfied: not powering down, not already in limp-in, time since the last solenoid activation > 72 micro seconds. The powertrain control module will set a trouble code if the actual state of the solenoid does not match the intened state.
Theory of operation: Its purpose is to regulate, by means of a duty cycle, the flow of vapors from the evap canister to the throttle body. The PCM controls the time the solenoid is on during a duty cycle. During off idle operations [higher flows], higher percentages of duty cycle are used. At idle [lower flow], lower percentages of duty cycle are used.
Possible Causes:
> Open or shorted control circuit
> Open fused ignition switch output circuit
> Open or shorted soienoid control coil
> Powertrain control module failure
> Connector terminals
> Connector wires
The most common problem with "Trouble Codes", I have found is the connecters or maybe in your case crushed wires?
Evap Solenoid Control > PK/BK and to cavity C20 on the Gray Connector at PCM.
Fused Ignition Switch Output > DB/GY and to the Ignition Switch.
If all looks good and without a DRB, I would try a Battery disconnect and let the PCM start over/relearn.
Let us all know how you make out.
Nadine, have you cycled your key to count the blinks on the engine light to establish a MIL code? Since most of us do not have a DRB handy, you may confirm your suspicions if you see MIL cobe 31...and/or you may find a second condition as well. Your Viper's plug should fit the generic (read that "el cheapo")scan tool...you know, the $100.00 type from the chain type auto store. On this tool you MAY find a generic code of P0443 representing "EVAP pump solenoid circuit"... "an open or shorted condition detected in the duty cycle purge solenoid circuit".
Or a P0441... "EVAP purge flow monitor failure"..."Insufficient or excessive vapor flow detected during evaporative emission system operation".
On later models, a P0442 has been added to alert one to a "small leak detected in the EVAP system".
Realizing that Wizard KNOWS about that which he speaks...and I DON"T...I still thought that a quick/cheap analysis might be in order...trying to keep DOWN the rising costs of replacing parts for diagnosis instead of for repair.
Good Luck !!!
Nadine,
The evap cannister purge solenoid clicks at a regular interval. It meters in small amounts of fuel vapor to the intake manifold depending on a number of computer sensor inputs. Worry not.
N
Nadine UK GTS
Bath, Somerset, UK
Thanks Guys, you're a great help, this board is fab for fast response, and a reassurance to an overseas gal! Yes, trouble code was set on mil for EVAP, and that's why I went to check it out and I discovered it clicking! Now I know it's cool to click! Disconnected PCM for a few mins and all seems well / reset...check engine light out, phew!
coronamartini
