Exhaust Leak
ruckdr
Renton, WA USA
Scott,
You said: The clamp is over a butt connection.
Do you mean the two joining pipes do not slip one into the other?
That won't work. Either weld, or go to a muffler shop and have a slip joint made that will receive both pipes, and use 2 clamps,
Good luck,
Later,
PETSN8K
memphis, tn
Hey guys, I need a little help.
I have located a leak from one of the clamps securing my straight pipe from the headers to the cat back. I have torqued down on that thing so that I don't think Hercules himself could tighten it anymore. It's still leaking. Not enough to hear, but you can feel.
It's also leaking enough that it is actually making my side sill just as hot as they were with the cats.
Could anybody tell me of a sure fire method of clamping a butt conection (not welding) to keep it from leaking.
Scott
