Flickering Lights AGAIN: Any perm solution????????
JohninFL
I searched previous threads on the 03 flicker prob and I could not find the ultimate solution for those cars that have had the factory reflash (mine)but continue to flicker. I dont drive at night much but I had the reflash done 6 months ago and all was fine until this week. The headlamp relay clicks loudly when the lights flicker. Help? New stalk req ?, New relay req ?, another reflash req or go back to the pre reflash response from DC " just turn the switch 10-20 times and hope?
Anyone else had the reflash and still twinkling down the highway flashing as if
the babies on the waaaaaaaaaaaayyyyyyyyyyyy. :eek:
nazology
Chicago
I have the flickering problem but its rare. Happens like once every couple of weeks, turning off the car and back on sometimes helps. Or just turn the lights on and off, I havent said anything to my dealer about this.
edretti
Severn, MD
I'm a service director for a Dodge dealer and I just looked up on dealerconnect that there is a recall C33 for that same exact complaint. If you had it previously done looks like there is an update to that software. I'd check it out at your dealer and see if it applies to you which looks to me it does. Hope that helps.
Viperfreak2
Duncan, SC USA
I had mine flashed the first time and it didn't work. The second re-flash took care of the problem, zero flickers in the last year and 1/2. Lemon laws would kick in with three failed attempts at a safety repair, at least in my state.
No members online now.
JpKL
