Forged pistons
IEATVETS
Cottage Grove, Wis.
I just purchased a 2000 GTS and as we all know it has cast internals. I will be installing a Paxton blower and probably replacing the pistons with forged ones so I can turn up the wick a little more. If I just replace the pistons, will I be fine? And how much HP/TQ are the cast pistons safe for anyways?
1TONY1
Dalton Ga. (Chatt. Tn.)
You can buy forged replacement pistons for a creampuff and you don't have to change the rods.
What rod depends on where the pin placement is in the piston. Roe sells the pistons.
I
IEATVETS
Cottage Grove, Wis.
Thanx guys. I will call Sean this week and talk to him as well. First order of business is getting the pistons swapped which will be done over the winter.
Racing Solutions
We are a JE Piston Dealer,and offer different options that you can get when ordering a custom set of Pistons. We also offer a Direct Replacment (same length) H-Beam rod for the 2000-2006 Viper that is bushed for a .927 pin, and also has ARP 2000 Rod bolts for $875.00
Jason
[email protected]
Andyk753
