FS: M2 Tuned Roe S/C with 7 Lb Pulley on Kuhmo's = 10.47@135
Larry Macedo
Sanford, FL
FS: M2 Tuned Roe S/C with 7 Lb Pulley on Kuhmo\'s = 10.47@135
Hello All,
Sadly a good friend of ours just sold his Viper and we will have his go-fast parts from his vehicle next Friday. We will install and retune this kit for $11,950.00 to fit your particular needs. The parts have roughly 3,000 miles clocked and are the following:
(1) Complete Polished Roe S/C Kit with 7 lb Pulley
(1) Set of Belanger Headers
(1) Corsa Cat-Back
(1) Set of 70mm Throttle Bodies
(1) 3" Smooth Tubes, Filters and Back-half Airbox
(1) MSD Boost A Pump
(1) 50 lb Injectors
(1) 96 PCM with Flashed Updates
(1) Crankshaft Pinning
(1) Dyno Tune 93/100 Octane Cards
Please feel free to Email or call us with any questions. Thank you!
Qualitywires.com
Louisville, KY
Re: FS: M2 Tuned Roe S/C with 7 Lb Pulley on Kuhmo\'s = 10.47@135
larry will you part out with the parts or is it a buy all at once?
FranciscoR.
Cincinnati, Ohio
I am not a pro, but it seems that for the amount of HP you would get, this 12g for parts, install, and tune is a steal. The charger itself is a good 6g or so.
L
Larry Macedo
Sanford, FL
The previous owner would like all of the parts to be sold together, guys.
John, I would love to upgrade your "creampuff" to 7 lb, but I'm afraid the outcome would be detrimental to your wallet. Besides, we can find alternate ways to make her faster and it won't hurt her a bit.
L
Larry Macedo
Sanford, FL
See above for all the parts you need to run a sub 10.5 pass at the drag strip on street tires.
VIPERCANE
Winter Springs, FL, USA
If I buy it does that mean I can come back to the front of the line and not get booted like a red headed stepchild???
The RT needs some power but it is a creampuff....
Shelby3
liu;g
Are you guaranteeing that this setup will run mid tens? What are you guaranteeing my setup will run? Include your air box in the calculation please Sir. :smirk: :usa:
Cudaman
USA
Larry does the old 10.47 sec driver come with the package?
Cudaman :usa:
2MANYTOYS
North Carolina
I'll take that driver! :D
For 3k more UGR can give you a 9 sec. car. :D :D :D
Seriously, that is a great deal especially with Macedo doing the work :2tu:
