Gasoline smell at startup of '94 RT-10.
Steve Ferguson
Burr Ridge, IL
Re: Gasoline smell at startup of \'94 RT-10.
Try a new gas cap. I had the same problem, it even led to gas leaking down the fender. Once we put on the new gas cap the problem disappeared!
Joseph Houss
NJ USA
Be careful, could be the fuel line... there is a connector near the firewall, that can (and did for me on my '96) come loose.
Also, if you own a '96 (and maybe '97?) there is a vapor cannister that might be the issue.
Steve Ferguson
Burr Ridge, IL
The first time I ever got a whiff of that foul gas smell, the cause of the problem led directly to the chilly I ate the evening before!
In all seriousness, I had the problem for a few years. The consensus was that the float was stuck, thus allowing for gas to seep out on certain occasions. It was Team Viper that suggested that I try the "new cap" before I start the complicated process of trying to make repairs to the float. Well the cap worked, and I have to had the problem re-occur since (except when I eat that **** chilly)!
Since you have a 94 RT10 I suggest you try the cap first. If it does not solve the problem at least you have a minimum investment in the repair!
And Mr. Houss, I know your cooking habits. This all but assures me that the gas smell you sensed in your GTS originated from the same location as the one I refer to above. When all else fails, refer to the laws of the land. Law #1, "never trust a skinny chef"! You know I WIN in that category.
Joseph Houss
NJ USA
Y'know Steve, come to think of it...I think I was on a Chili binge during that time.....hmmmmmm.
LOL
gtsviper
Huntington Beach, Ca, US
I get a faint whiff of coolant when I start my new 00 R/T 10. The smell disappears quickly. Have looked for coolant leaks and none located. No apparent loss of coolant from the expansion tank.
Any ideas?
Quantico, VA
Carl,
I also used to have this gas smell. It was the gas cap. Of course mine was because I couldn't follow the tough directions of tightening until three clicks. It does make a difference.
ViperGear
