GeorgeJKatsoulis
Apologies if this has already been discussed. I couldn't find what I needed. I have a 98 RT-10.
I am changing the differential fluid and the transmission fluid. I found conflicting information as I was doing research. For example, I was told that I need 4318060AB friction additive but AC and AD have come out after AB. Are they better?
Basically, I'm hoping someone can give me links to the 3 fluids that I need. Also, to flush the clutch, how do you go about doing that. Do you need to buy more that 2 quarts of diff fluid?
