Gen 3 larger, high performance radiator help
aries
Laurel, MD
Hey guys, I'm looking for a larger, better cooling radiator for my SRT10 Coupe. It's 540ci twin turbo so I'm creating a little more heat than stock. ;). The stock radiator does well as long as I'm not driving it hard for too long, but even short blasts have the temp gauge moving up. Thanks
Cape Coral, FL
What is your exact configuration with regard to intercooler, fans, etc?
The stock radiator and cooling fan are EXCELLENT on the SRT's, and short of blockage issues, they wont have a problem cooling much of anything. Larger radiators wont solve your problem, and will likely create others, as they do not tend to last nearly as long due to design flaws. Adding more cores to an already sufficient radiator will simply decrease the overall flow rate.
I suspect that you are blocking the radiator with an intercooler, and if that is the case, the first place you want to look is increasing air-flow, and adding push or pull fans to your intercooler so that the radiator actually has decently cool airflow available.
Pictures of the front would help as well.
A
aries
Laurel, MD
I suspect that you are blocking the radiator with an intercooler, and if that is the case, the first place you want to look is increasing air-flow, adding push or pull fans to your intercooler so that the radiator actually has decently cool airflow available.
You hit the nail on the head, I have a large intercooler in front of the radiator. Like I said, the stock radiator does remarkably well considering the mods.
A
aries
Laurel, MD
Here's some pics.
No members online now.
JpKL
